  Visitors: 4334
CAD tip CAD tip # 7761:
Borders and X on decals in Revit.
A - answer Decals applied on Revit scene objects are displayed with borders and diagonal "X" across the decal image in realistic visual styles. It disturbs the scene which uses e.g. the Ambient occlusion style.
You cannot control these decal lines globally by overriding a separate category but you can disable the individually. Right-click on a line on the sticker and remove them using Override Graphics in View -> By Element... - check the "Transparent" option.
See the sample (CZ version shown):
Revit2011
28.1.2011    7570×
Prices - CAD eShop:
applies to: Revit 2011 ·
Tip 12365:How to show color print (sketch) also on the sheetmetal flat pattern?
Tip 8862:Error on publishing iPart to your library in CC (external dependencies).
Tip 7178:How to create a picture on a wall in Revit?
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
