Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 7905:
Question
Autodesk Showcase 2012 supports (through the included DirectConnect) the import of 3D CAD models from the following file formats:
  • AutoCAD drawing (.dwg)
  • Autodesk 3D scene (.a3s)
  • Autodesk Alias (.wire)
  • Autodesk Inventor (.iam, .ipt)
  • Autodesk Packet (.apf)
  • CATIA V4 (.dlv, .dlv3, .dlv4, .exp, .mdl, .model, .session)
  • CATIA V5, incl. R20 (.catpart, .catproduct, .cgr)
  • Cosmo scene (.csb)
  • DXF (.dxf)
  • DirectModel JT (.jt)
  • FBX (.fbx)
  • Granite (.g)
  • IGES (.iges, .igs)
  • NX, incl. V7/7.5 (.prt)
  • Open Inventor (.iv)
  • Pro/Engineer,Creo (.asm, .prt)
  • STEP (.step, .stp)
  • SolidWorks (.sldasm, .sldprt)
  • Stereolithography (.stl, .stla, .stlb)
Export of the resulting Showcase presentations can be performed to the video formats AVI, MP4, FLV, MOV or to image sequences.
Showcase is included in the new Autodesk Design Suites.
Showcase
10.4.2011    16216×
Share the tip:
applies to: Showcase ·
Tip 9817:Output from Autodesk Showcase as a mosaic on multiple monitors.
Tip 9735:How to convert a .THING file to a 3D CAD model?
Tip 9719:Animating constraints in Showcase: AdWorkflowHost is unknown.
Tip 9654:CAD formats supported in online viewer under Autodesk 360.
Tip 9549:Rendering of 3D models without background in Autodesk Showcase.
Back    All CAD Tips
Categ:
