  Visitors: 3482
CAD tip CAD tip # 7044:
Cannot install AutoCAD on a 64-bit version of Windows?
A - answer If you try to install AutoCAD (or LT, AutoCAD Architecture, Mechanical, Electrical, etc.) on Windows 7 64-bit, Vista 64 or Windows XP x64, you may get a message saying that your 32-bit AutoCAD is not compatible with this 64-bit operating system.
Just install the right version of AutoCAD. Make sure you are installing the 64bit version of AutoCAD included on your official installation media (some versions have a separate setup.exe in the x64 folder on the DVD). Most AutoCAD-based CAD products (since 2008) are distributed in both 32-bit and 64-bit versions. These 64-bit versions are officially supported in XP x64, Vista 64 (since 2008) and Windows 7 (since 2010).
Recent AutoCAD versions are supported only in Win7, Win8/8.x and Win10 (as separate 32- and 64-bit versions).
ACADLTADTACADMACADEInvDWG
8.11.2009    44451×
Tip 12766:Lines with a single grip, incorrect osnaps, intersections, offsets, hatches - CheckLarge
Tip 11959:Supported file types (applications) with reference detection in Autodesk Desktop Connector.
Tip 11659:Where can I download the 32-bit Object Enabler for AutoCAD Civil 3D 2018?
Tip 11450:How to run Fusion 360 in a web browser? (URL)
Tip 10964:MS Office 2016 support in Autodesk Vault.
