  Visitors: 7385
CAD tip CAD tip # 8030:
Click2XLS - click points to export from AutoCAD to Excel.
A - answer With the free AutoCAD add-on utility CADstudio Click2XLS you can automatically export all "clicked" coordinates to an Excel table.
Download Click2XLS from Download, load it with APPLOAD and start the CLICK2XLS command.
This either creates a new Excel table or connects to an existing (opened) table at the selected cell. Any clicked points will be then copied over to individual rows in the Excel sheet.
This video shows how it works:
Since version 1.4, Click2XLS also contains the Text2XLS command which transfers picked drawing texts to Excel (supports any text entities except table cells written in a TrueType font).
Since version 1.5 you can insert blank lines (the option "Blank") to the XLS table.
Since version 1.7 you can toggle between the row and column insertion modes for coordinates.
See also the XLS2Curve utility and Click2OO (for OpenOffice Calc).
Click2XLS and many other freeware tools are available on www.cadstudio.cz, other CAD videos on CADstudio's YouTube channel.
ACAD
9.6.2011    52458×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13784:Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT?
Tip 12926:How to import point coordinates from Excel to AutoCAD?
Tip 11913:Simple export of vertex-coordinates from a selected polyline.
Tip 11076:Reading and displaying 3D point matrix from a CSV file.
Tip 10709:How to create a profile from imported XYZ points in Fusion 360?
