  Visitors: 13290
CAD tip CAD tip # 12866:
Compare performance in Fusion 360 - avoid complex sketches.
A - answer When working in the CAD/CAM application Autodesk Fusion 360, keep in mind - even more than in other parametric 3D modelers: always keep as simple sketches as possible and model any geometric features later in 3D!
Efficiency and resulting performance of the model can be strongly dependent on a correct modeling procedure - and the more complex the final design, the more apparent will any erroneous procedures become.
Let's show the differences on a relatively simple model of a comb (array of 25x25 spikes). How will be its performance influenced by two variants of modeling procedure - creating the spike array in a sketch, or arraying the resulting 3D model. Compare:
Follow our tips and tricks for optimal modeling in Fusion 360.
Fusion360
100% *  CAD,CAM
8.2.2021    4130×
Prices - CAD eShop:
applies to: Fusion 360 360 ·
Tip 13944:Intersection of a 3D spline with a plane in Fusion 360.
Tip 13805:Projecting/embossing a profile on a curved surface in Fusion 360.
Tip 13760:Parametric text content in Fusion 360 sketches (and models).
Tip 13719:How to load a 2D DWG drawing of a part into Fusion 360?
Tip 13433:How to create a parametric dynamic 3D block in AutoCAD?
