  Visitors: 7551
CAD tip CAD tip # 8610:
Compatibility of Vault server 2013 with older client versions.
A - answer ADMS 2013, i.e. Vault server version 2013 can be used in combination with client versions of Vault 2013 but also with Vault clients version 2012.
This extended compatibility applies also for additional "ADMS/Vault client upgrades" (see Download) installed e.g. on top of old Inventor vesions. After the installation of the appropriate "ADMS 2012 client upgrade" to Inventor 2011 or 2010, you can still use these older client applications with the new Vault server version 2013.
In such combined client-server application you will have only functions available in the older version of the client and the new functionality will become available only after you install the new client version 2013.
Vault2013Vault2012Inv
30.4.2012    5906×
Prices - CAD eShop:
applies to: Vault 2013 · Vault · 2012 · Inventor ·
Tip 12893:"Publish is not Successful" when editing a family in Content Center.
Tip 12555:Can I upgrade my CAD/PDM server to Windows Server 2019?
Tip 11210:Largest number of versions among Vault documents.
Tip 10342:Compatibility of Vault Server with older versions of Vault clients.
Tip 6945:How to transfer a Content Center library to or from Vault server?
