  Visitors: 3473
CAD tip CAD tip # 9176:
Confirm loading of LSP, VLX, DLL, ARX application files.
A - answer In default settings, AutoCAD 2014 checks automatic loading of executable files and warns before loading of add-on files from other than "secure" folders (trusted folders can be added using Options > Files).
If you want to avoid confirming individual applications when starting AutoCAD, add your app folders to the "trusted" list or temporarily disable the security checks by setting the SECURELOAD variable to 0.
ACAD2014
3.4.2013    9194×
Prices - CAD eShop:
applies to: AutoCAD 2014 ·
Tip 12136:Security settings for Inventor data files and add-on applications.
Tip 9500:File loading warning - security concern (executable file).
Tip 7739:Empty (white) activation window.
Tip 7230:Failed previews and downloaded documents in iProject.
Tip 4317:FATAL ERROR: Unhandled Access Violation Reading 0x0054 Exception at 72c214h
