  Visitors: 8840
CAD tip CAD tip # 9651:
Convert a DWG 3D mesh model to an Inventor 3D solid part.
A - answer The following video-tip illustrates how to convert a 3D mesh (surface) model (e.g. from a DWG file) to a solid body using Inventor's stitch function. The mesh model is composed from 3DFaces and it has to be watertight - fully enclose a volume. If you generate your surface model algorithmically (e.g. using 3DPlot) or with ReCap functions, try to keep it simple.
When importing your DWG file, make sure you click through the folder structure in the Open dialog - do not just paste the full filename. In the import wizard, check the neccessary options to load the DWG objects to a 3D part file.
The loaded model is a surface model (has e.g. no volume in iProperties). You can stitch it to a solid part (stitching can use a tolerance setting). The solid part can be then re-exported to a DWG or other CAD formats.
Inventor
18.1.2014    15810×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13805:Projecting/embossing a profile on a curved surface in Fusion 360.
Tip 13472:How to convert the structure of a volumetric lattice to a real mesh body?
Tip 13211:Automatic numbering/renaming of multi-volume bodies in a part.
Tip 13163:Blended transitional solid between irregular regions, circle-rectangle transition (3D in AutoCAD)
Tip 13021:Rotating model when hovering above a 3D point cloud. How to disable?
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
