  Visitors: 7023
CAD tip CAD tip # 12830:
Converting pseudo-tables consisting of lines and texts to TABLE objects in AutoCAD DWGs.
A - answer Using the freeware utility COT (Convert Old Table) you can convert tables in your AutoCAD DWGs, manually sketched (even inaccurately) as parting lines, rows and columns with texts and blocks, to real TABLE-type objects. Those objects are much easier to format, edit, add or delete rows/columns, merge, or export to Excel.
Download the LISP utility COT from Download, load it into your AutoCAD with APPLOAD and run it by typing the COT command. Select the objects creating a table (including outline and parting lines) and choose whether to keep styles and headers. The conversion will handle most combinations of texts, blocks and merged table cells.
Sample:
(author of the utility: Juan Villarreal, fixes and additions: CAD Studio)
ACADADTPlantACADMCivilMap
29.12.2020    7188×
Tip 13855:DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder.
Tip 13784:Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT?
Tip 13757:Bulk editing of drawing properties (DWGprops) from Excel.
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13522:LookupXLS - populating DWG texts from Excel spreadsheets.
