  Visitors: 8464
CAD tip CAD tip # 11223:
Copy multiple DWG drawing texts to the Windows Clipboard.
A - answer The freeware utility CCText (see) allows mass copying of selected texts from the current AutoCAD drawing to other Windows applications through the Windows Clipboard.
Select the drawing texts (line and paragraph texts, optionally also block attributes) and specify the ordering of clipboard texts. Then paste the copied DWG texts e.g. to Word or other application using the standard Ctrl+V (copy-paste).
The option "Attribs" toggles accepting attributes into the export. The texts are sorted to the Clipboard by default in the order of selection (as picked). Optionally you can order them by "X" (i.e. left-to-right), by "Y" (top-down), or by columns (top-down, then LTR). You can also preset automatic replacement of a given substring in the transferred texts.
By setting the variable _CCtextNoReformat you can disable automatic replacing of the control code \P with new-line in paragraph texts (MTexts).
(setq _CCtextNoReformat T)
You can download the CCtext (clipboard-copy text) application from Download, load it with APPLOAD and start it by typing the CCTEXT command.
See CCtext in a sample video:
ACAD
15.12.2016    8298×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 14039:How to display the total volume or surface of 3D solids in DWG?
Tip 14007:Workaround for the missing (vlax-create-object) in AutoCAD LT (voice, clipboard, etc.)
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13824:How to export OBJ including materials, textures from Inventor?
Tip 13805:Projecting/embossing a profile on a curved surface in Fusion 360.
VRMLout More info
