  Visitors: 5098
CAD tip CAD tip # 12950:
Custom installation of Autodesk 2022 CAD/BIM software products.
A - answer Autodesk 2022 products have a new, simplified installation with no unnecessary questions or prompts. However, if you need to perform a customized installation, or if a CAD administrator needs to prepare a single installation (deployment image) for the entire company, setting up the necessary libraries, folders and add-ons, there is a "Custom Install" tool in your Autodesk Account.
You can invoke it by logging into your subscription administrator account in the "Products & Services" menu on the left. Select the desired product or products from the list of applications and choose the license type. Then, in the right-hand column, you can set all the desired options, just as you would do it in the original installation wizard with the Custom option.
Press the Next button to choose whether you are creating an installation package or a network deployment and the installation folder. This will create a customized installer that installs the preconfigured environment of your selected products without further questions.
The feature builds on the original creation of network deployments in Autodesk Account.
Example - Revit 2022 with Czech RFA content libraries (click to enlarge):
Custom Installation - Revit 2022
ACAD2022Revit2022Inventor2022Civil2022Vault2022Max2022Maya2022ReCap2022
13.5.2021    3696×
Tip 12442:Non-modal (permanent) iProperties window in Inventor - SelectionInfo.
Tip 12108:The Tic-Tac-Toe game in Inventor.
Tip 11145:AutoCAD: Customization file load failed.
Tip 11016:How to copy Revit custom colors to another PC?
Tip 10556:AutoCAD 2015 and 2016 do not allow to select paper size for Designjet T120/T520.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
