  Visitors: 7260
CAD tip CAD tip # 11428:
Differences in typed distance/offset values in Inventor sketches.
A - answer When you specify a length, radius, chamfer or offset in an Inventor sketch using a numerical, typed value (in HUD), the real used value may differ from the user-entered one. The differences from the exact value may be in an order of tenths or hundredths.
This can occur when you have enabled snapping to a fixed coordinate grid. Values are "rounded" to that grid. Disable this option in Application Options > Sketch > Snap to Grid.
Inventor
17.5.2017    9428×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13965:Total length of sweeps in Inventor - wires, pipes, trusses, tubes, hoses (iLogic)
Tip 13197:How to transfer a model or sketch parameter to iProperties?
Tip 12152:Sketch lines linewidth - how to make Inventor lines thicker for a 4K display?
Tip 12046:Random shape and appearance of an Inventor part or assembly.
Tip 11240:Fusion360: Extrusion offset from a sketch plane.
LogOff 2006 More info
