  Visitors: 11799
CAD tip CAD tip # 13552:
Differential dimension X,Y
A - answer To dimension the difference between the X- and Y-coordinate components of two points, indicating the positive (+) or negative (-) value of the difference, you can use a simple differential dimensioning utility in AutoLISP.
Download the DIMDIFF.LSP file from Download, load it into your AutoCAD using APPLOAD. Type the DIMDIFF command and pick both dimensioned points (positions). A (non-associative) dimension with the coordinate component differences is drawn.
ACADADTACADMPlantMapCivil3D
23.11.2022    3240×
Tip 13831:ReplMTcol - recoloring parts of text in paragraph Mtext.
Tip 13760:Parametric text content in Fusion 360 sketches (and models).
Tip 13749:How to add the SEARCH/REPLACE command into AutoCAD Web?
Tip 13587:Dynamic label of 3D coordinates.
Tip 13091:3DSolSz - list of dimensions of selected 3D solids.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
