  Visitors: 5646
CAD tip CAD tip # 9336:
Dimensional value or resultant geometry is inconsistent with existing configuration.
A - answer This error message displayed when attempting to create a parallel geometric constraint (align) between a curve and a text (GCPARALLEL) may be caused by two factors.
  1. The curve is a part of another existing constraint (e.g. tangential) and this contraint was not created properly. Remove the tangent-constraint.
  2. The aligned text is using TrueType fonts - this can cause constrain problems in some cases. Temporarily change the text to use a SHX font, create the constraint and then change the text back to TrueType.
ACADADTACADMCivilMap
15.7.2013    6755×
Tip 13185:Constraining object movement to a specified curve (rail) in AutoCAD.
Tip 12961:Bolt-nut constraint/joint in Fusion 360.
Tip 12856:How to force Inventor holes in existing points only?
Tip 12762:Multiline and vertical text in Fusion 360 sketches.
Tip 12755:How to create a polyline with multi-colored segments?
