  Visitors: 5294
CAD tip CAD tip # 11222:
Directional copying of AutoCAD drawing objects.
A - answer With the freeware utility CoDOf (see) you can easily copy drawing objects in a given direction.
Multiply the selected objects by specifying two independent parameters - the direction and offset (distance). You can then repeat the offset manually or automatically (number of repetitions), or you can change it on the go.
Download the application CoDOf (copy with directional offset) from Download, load it with APPLOAD and run it by typing the CODOF command.
See CoDOf in a sample video:
ACAD
15.12.2016    3706×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 12896:How to perform multiple copying with relative offset to the last copy?
Tip 10167:Keyboard shortcuts in Autodesk Fusion 360.
Tip 8434:Copy/Paste functionality with added support for UCS.
Tip 8322:How to extract intersection lines or edges from 3D objects?
Tip 7800:How to model a 3D hyperboloid?
Simply link AutoCAD LT blocks to Excel table data.
Excellink LT 2006 More info
