  Visitors: 7008
CAD tip CAD tip # 11106:
Displaying IfcSpace in Autodesk Navisworks.
A - answer To display room and space objects saved in an IFC file (the IfcSpace class) first enable the option Convert Spaces in Navisworks options (File Readers > IFC). This will load rooms to your Navisworks project - then just click the command Unhide All on the Home ribbon to display these objects.
NW
26.9.2016    5962×
Prices - CAD eShop:
applies to: Navisworks ·
Tip 13844:With which subscriptions do I get Autodesk Drive cloud storage as a bonus?
Tip 13597:How to convert RGB color to Pantone, RAL, AutoCAD ACI, CMYK or vice versa?
Tip 13404:How to import an IFC file in AutoCAD?
Tip 12348:Is it possible to import SketchUp SKP files 2013, 2018,2019 or 2020 into Revit?
Tip 11818:How to change resolution of images in the Clash Detective report in Navisworks?
Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally.
Try Excellink 2015 More info
