  Visitors: 4541
CAD tip CAD tip # 8764:
Do I need to install SP1 before installing SP2?
A - answer Different types and versions of Autodesk products have different policy of installing Service Packs (or "Product Updates").
E.g. starting with Inventor 2012, every higher Update (SP) also contains all lower (older) Updates and so it is not neccessary to install the whole history of updates - you can directly apply e.g. "Update 2" (Service Pack 2) to the original version of Inventor (sometimes called "SP0", "RTM" or "FCS").
If you apply the updates incrementally, you can also uninstall them incrementally. So by uninstalling SP2 you will get Inventor with the SP1 installed, including its possible hotfixes installed before SP2.
To distinguish whether a particular Service Pack contains also the older SP versions, or whether it requires to install them, you can use the description of the Service Pack on our Download page. The text "incl.SP1" means "already contains also SP1", on the other hand the text "reqs.SP1" means "requires a previous installation of SP1".
ACADInvADTMechRevitmax
16.8.2012    10495×
applies to: AutoCAD · Inventor · AutoCAD Architecture · Mech · Revit · 3ds Max ·
Tip 13505:How to find which version of Inventor has saved a file?
Tip 12950:Custom installation of Autodesk 2022 CAD/BIM software products.
Tip 12412:Missing category icons and thumbnails in Inventor Content Center.
Tip 11479:"Assertion failed" error when launching AutoCAD.
Tip 11082:Wrong license cascading on Inventor in Product Design Suite 2017.
VRMLout More info
