  Visitors: 7778
CAD tip CAD tip # 7354:
Double-click hatch edit in AutoCAD 2011.
A - answer In AutoCAD 2011, you can use a simple hatch editing through the new context ribbon. Just select the hatch and you can change any of its properties.
If you want to edit hatches by double-clicking as in the older AutoCAD versions, set the "Double-click action" in the CUI dialog - for the object type Hatch set (drag) the command "Edit hatch" (instead of Properties). Exit the dialog with OK.
ACAD2011LT2011ADT2011Civil2011
9.5.2010    19692×
Tip 13802:Dual-color hatches in AutoCAD.
Tip 13788:Green square - mathematical charade and parametric constraints in AutoCAD.
Tip 13590:How to set the hatch background color?
Tip 12966:TrimArr - trim a dynamic array to a boundary curve.
Tip 11751:toMulti converts polylines to multi-lines driven by a definition table.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
