  Visitors: 10121
CAD tip CAD tip # 6802:
Draping an aerial image on a Civil 3D terrain surface.
A - answer If you have an aerial image (satellite image, aearial photography, map) of the territory you work on, you can use the AutoCAD Civil 3D function for draping images on triangulated 3D surfaces.
As Google Earth is the most used source of such aerial images, you can also use the direct and easy way - the internal GE import function (ImportGEImage) - to load a georeferenced image from Google Earth (caution - does not work properly in some versions of GE).
But you can use any source and any standard raster image file. To project such file on a terrain surface, use the following steps:
Attach the image (IMAGEATTACH) in the plan view of your project, in a proper location (georeference) and size (scale). It will appear under the terrain surface.
Attach image
Start the DrapeImage command - i.e. click on a surface and in the ribbon "Surface > Utilities" choose the "Texture drape" function. In the dialog then select the requested image and surface.
DrapeImage dialog
Now, the image is applied to the surface object. If you look at the project from a 3D view, apparently nothing has changed (TIN model displayed):
Surface in 3D
But if you change the visual style (VISUALSTYLES) to Realistic (or run the RENDER command), the surface will show the projected texture of your image (you can suppress the original 2D image e.g. with "Isolate objects > Hide" in the context menu):
Visual style Realistic
In the Material Editor (MATERIALS) you can verify the automatic creation of the material attached to the terrain surface object.
Materials
Civil2010Civil2009Civil2008
20.7.2009    29999×
Prices - CAD eShop:
Tip 13512:How to open Google Earth directly in your AutoCAD window?
Tip 13296:How to correctly load a KML/KMZ file into Civil or Map 3D?
Tip 9375:How to import 3D CAD data into Autodesk FormIt?
Tip 9197:Export of 3D CAD models to Google Earth.
Tip 7852:Put Google Earth maps directly into AutoCAD.
VRMLout More info
