  Visitors: 13775
CAD tip CAD tip # 9829:
DrGrid - parametric grid for AutoCAD drawings.
A - answer zgrid If you need to draw a rectangular orthographic or polar underlay (matrix, network, X-Y line raster) in your AutoCAD DWG drawing, you can use the free add-on utility CADstudio DrGrid from Download.
This generator automatically creates a regular Y- and Y-axis line grid (linear or logarithmic) or a polar circular grid in a specified area. The default offset equals to the current visual grid step (F7). Optionally you can autonumber the drawn lines. Every N-th line can be emphasized. In the 3D mode, a cube (box) grid is generated.
The generated underlay grid is created in a given layer (can be set as non-printing), in a given color and linetype. The grid layer is locked and drawordered to the back of your drawing. It is cleared before any new grid is drawn.
DrGrid - visual grid as real drawing entities (objects).
Polar grid numbered, sample function from 2DPlot superimposed:
Examples of DrGrid:
You can use LISP variables to predefine grid parameters:
(setq DrGridLayer "DrGrid") ; layer
(setq DrGridColor 8) ; color
(setq DrGridMajColor 9) ; majors color
(setq DrGridTransparency 30) ; transparency
(setq DrGridLabelScale 0.5) ; relative label scale
(setq DrGridLineType "DOTTED") ; linetype
(setq DrGrid3D T) ; in 3D?
(setq DrGridPolar T) ; polar grid?
(setq DrGridNumber T) ; numbering?
(setq DrGridLogStartOrder -2) ; logarithmic starting label (order)
(setq DrGridLog T) ; logarithmic
GRID command names: RASTR RASTER GRILLE REJILLA GRIGLIA GRADE SIATKA
ACAD
16.5.2014    21961×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13933:How to set grid colors in AutoCAD Web?
Tip 13221:Attractor - snap multiple objects to existing points/vertices.
Tip 11936:Why does AutoCAD display an oblique (skewed) plan view and a red-green crosshair?
Tip 11914:Maze generator for AutoCAD.
