  Visitors: 5180
CAD tip CAD tip # 10945:
DWG text in dashed or dotted linetype.
A - answer Drawing texts in AutoCAD do not use linetypes, i.e. DWG text entities do not respect their linetype setting (neither through properties nor layers). If you need to display or print any text as dashed lines (or dashdot, dotted), you can use these methods:
  1. Explode the text to lines - see the Tip 1901 and assign the requested linetype to them
  2. Use a special font for the texts - e.g. the fonts DASH.SHX, DOT.SHX or DOTFONT.SHX
  3. Use a plot style with a dashed linetype - only for SHX fonts, not for TTF. Do not assign the linetype via properties but use a color- or name-dependent plotstyle (set its Linetype property in the CTB/STB table):
ACADLT
6.6.2016    12079×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 13450:How to create a complex line type with text always upside down?
Tip 13435:Bulk setting of layer properties according to the object in that layer.
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
Tip 12755:How to create a polyline with multi-colored segments?
Tip 12475:Mysterious text rotation when editing.
