Over 1.092.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
CAD tip # 13587:
Question
Using automatic text fields referencing the properties of a block reference, you can create a 3D block with a dynamic label of the X/Y/Z coordinate of its insertion point. So you can easily dimension "ordinate" points in 3D - e.g. corner points on your 3D model.
An example of such block can be downloaded from the Block Library - Block 22452: XYZlabel.dwg. When pasted with the appropriate 3D osnap modes, the block will display the values of the individual components of the insertion point coordinate - X, Y and Z (in the planes of that component coordinate).
An example:
ACADACLTCivil3DMapPlant3DADT
30.12.2022
61721×
applies to: AutoCAD · AutoCAD LT · Civil 3D 3D · AutoCAD Map 3D · AutoCAD Plant 3D 3D · AutoCAD Architecture ·
