CAD tip # 10855:
applies to: AutoCAD · AutoCAD Architecture · AutoCAD Mechanical · AutoCAD Plant 3D · Civil 3D · AutoCAD Map 3D · |
Tip 13878: | SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions |
Tip 11830: | How to influence linetype scale or color for hidden edges in documentation views? |
Tip 11146: | Metric linetypes by ISO and complex linetypes for utilities. |
Tip 9829: | DrGrid - parametric grid for AutoCAD drawings. |
How to invoke a nested script (.SCR) in AutoCAD?
How to suppress a surface body in rendering of an assembly? « | » iLogic - how to get part material and path from a drawing?
