  Visitors: 3564
CAD tip CAD tip # 10329:
Easily share your Fusion 360 design.
A - answer You can easily share you 3D models in the CAD/CAM application Autodesk Fusion 360 with collegues or communities - either publicly or behind a password.
Open the Data panel (left) and right-click on the requested model. Choose "Share Public Link" from the context menu.
In the following dialog then copy the unique URL address with access to your design (web 3D viewer) and specify whether you also want to allow downloading of the model in the source format .F3D and in CAD exchange formats and whether it is password-protected.
The visitor will be able to choose from multiple CAD formats for the download: Fusion360, Inventor2014, DWG, DXF, IGES, STEP, SAT, STL and FBX.
A similar sharing can be also initiated from your project (cloud repository, hub) in Autodesk A360.
Fusion360A360
24.5.2015    4843×
Prices - CAD eShop:
applies to: Fusion 360 360 · A360 ·
Tip 13770:How do I revert to a previous version of the model in Fusion 360?
Tip 13719:How to load a 2D DWG drawing of a part into Fusion 360?
Tip 13595:How to transfer 3D model incl. toolpaths from Inventor CAM to Autodesk Fusion 360?
Tip 13557:How to create an image with transparent background in Fusion 360?
Tip 13402:Which products and features can I use for free with Flex Token licensing?
