  Visitors: 5880
CAD tip CAD tip # 7394:
Edit material texture size in AutoCAD 2011.
A - answer If you need to change any of the predefined materials in the AutoCAD 2011 material library - e.g. edit the texture size (scale), you can use the following procedure.
To individually change the mapping (scale, method) of material textures for single objects in your drawing (scene) use the command MATERIALMAP.
To change the material definition (e.g. to set the tile size for tiles applied as a texture) use the "Material browser" palette (MATERIALS). Select the requested material - this will copy it to the list of the document materials on the top. Now double-click on this document material (or right-click and select Edit) and the palette (dialog) Materials Editor will be opened. There double-click on the texture image or right-click (or use the arrow) and select "Edit image". In the "Texture Editor" palette use the Transforms > Scale field to change the size of the material texture (Sample size).
Material Editor in A2011 (CZ version)
ACAD2011ADT2011Civil2011
7.6.2010    35503×
Prices - CAD eShop:
Tip 13522:LookupXLS - populating DWG texts from Excel spreadsheets.
Tip 13095:How to change material texture orientation in Fusion 360?
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
Tip 12833:RAL color library (palette) for Fusion 360 (plus BS, AS, NCS).
Tip 12620:All-white display of a 3D model in AutoCAD realistic view.
LogOff 2006 More info
