  Visitors: 693
CAD tip CAD tip # 8844:
Error 1618 while installing Revit.
A - answer When Installing or updating Autodesk Revit, you may receive an installation error:
Error Code: 1618
Or: Installation aborted, Result=1618
This error indicates that another instance of the Windows installer is already running. This is often be caused by a failure of a previous installation. In most cases a system restart will help, or you can try to rerun the setup with higher user rights (Administrator). Also try to temporarily switch off the Windows User Account Control (UAC).
RevitACADInv
8.10.2012    25946×
applies to: Revit · AutoCAD · Inventor ·
Tip 13539:Revit 2023.1 shows "Twinmotion is not installed"
Tip 12605:Script error (utag) when trying to log-in with your Autodesk ID.
Tip 11863:You cannot install this product on the current operating system.
Tip 11375:System error: The program can't start because mfc120u.dll is missing
Tip 10084:Error "Unsupported operating system" when installing Revit LT 2015.
