  Visitors: 5397
CAD tip CAD tip # 9081:
Error: Bad DXF group: (10)
A - answer During command execution, AutoCAD reports the error:
error: Bad DXF group: (10)
Typically, this type of error may occur inside an add-on application (custom utility). It means that the application has attempted to create an entity with wrong vertices (a polyline with a single vertex, identical endpoints for a line, etc.). I may be a programming error or a result of wrong geometry in the processed drawing. Check the status of your drawing with the AUDIT command and purge any null lines (-PURGE > Zero length geometry).
ACAD
11.2.2013    7613×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 12347:Invalid or incomplete DXF input -- drawing discarded.
Tip 10820:Unable to save to drawing c:\folder\filename.dxf
Tip 7463:One or more objects in this drawing cannot be saved to the specified format.
Tip 7164:The NLS files required to convert the text entities...
Tip 6119:Lost dynamic properties (grips) of dynamic blocks.
