New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 12131:
Question
AutoCAD has suddenly started to report an error on proven LISP programs: "no function definition: VLAX-ENAME->VLA-OBJECT" or on any other VLAX- or VLR- function call (e.g. VLR-MOUSE-REACTOR).
This may have several causes - from the most frequent:
  1. A missing call to the function loading the "VLAX" support for accessing the ActiveX programming interface - i.e. (vl-load-com) - try to type it on the AutoCAD command line and retry your LISP program.
  2. You are trying to run your LISP program in AutoCAD for Mac - but this version doesn't support the Windows-specific (ActiveX) VLAX functions.
  3. A damaged or missing or antivirus-blocked file adding the VL-functions, i.e. VL.ARX - should be in the folder C:\Program Files\Autodesk\AutoCAD 20XX\
  4. A missing reference to the class type library. Check these Registry settings using the Regedit application (replace "XX" and "##" with the version available in your AutoCAD folder - e.g. "vl16.tlb"):
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{A4081F53-974E-479E-A26E-E6DE9A5B2489}]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{A4081F53-974E-479E-A26E-E6DE9A5B2489}\1.0]
    @="Visual Lisp ActiveX module"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{A4081F53-974E-479E-A26E-E6DE9A5B2489}\1.0\0]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{A4081F53-974E-479E-A26E-E6DE9A5B2489}\1.0\0\win32]
    @="vl##.tlb"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{A4081F53-974E-479E-A26E-E6DE9A5B2489}\1.0\0\win64]
    @="C:\\Program Files\\Autodesk\\AutoCAD 20XX\\vl##.tlb"
You can also download the .REG file VlrLspFix.reg, edit the name of your AutoCAD folder in it and then "run" it by double-click.
ACADCivilMapACADE
2.2.2019    18861×   Expert
Tip 13822:Fast layer visibility toggle ON/OFF.
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13529:How to redefine the behavior of a standard AutoCAD command?
Tip 12210:How to erase a specific object type in all DWG layouts?
Tip 11996:How to rotate selected blocks by the angle of an existing block?
Back    All CAD Tips
Categ:
