  Visitors: 7431
CAD tip CAD tip # 8862:
Error on publishing iPart to your library in CC (external dependencies).
A - answer When trying to publish a Part to your library in the Inventor Content Center you get an error message:
There are external dependencies found in the document. Please remove the dependencies then proceed with this command.
The most usual source of this problem is referencing a texture file (bitmap in a material- or decal definition), which is not stored in the default project (project search paths). The default location for textures are subfolders of C:\Users\Public\Documents\Autodesk\Inventor 20XX\Textures\. Break or modify the links to your complaining textures (see Tools > Options > Manage Links) and then retry the publishing.
Inventor
16.10.2012    8100×
Prices - CAD eShop:
applies to: Inventor ·
Tip 12779:How to export a hi-res image from Autodesk Infraworks?
Tip 12644:How to identify parts and assemblies imported from STEP/IGES?
Tip 12317:How to publish a custom iPart to CC with Color as one of its parameters?
Tip 11277:How to share simulation results from Fusion 360?
Tip 10258:Digital signature of CAD files in the DWFx format.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
