  Visitors: 6057
CAD tip CAD tip # 10955:
Evaluate VBScript functions from AutoLISP.
A - answer Sometimes you may prefer to use a VBScript function over AutoLISP as it would be easier, faster or more convenient than the native LISP (VisualLISP) program code.
The evalVBS function is a wrapper for these situations. You can use it to quickly run any VBScript code from inside your LISP routines. Download the evalVBS.LSP source code by CAD Studio from Download, load it and call it with (evalVBS "myVBScodeString").
;examples (use 'result' for any return value):
;(evalVBS "MsgBox(\"Hello world!\")")
;(setq mystring2 (evalVBS (strcat "result = LCase(\"" mystring1 "\")")))
;(evalVBS "MsgBox(\"VBcommand 1\") : MsgBox(\"VBcommand 2\")")
;(evalVBS "MsgBox(\"VBcommand 1\")\nMsgBox(\"VBcommand 2\")")
;return values:
;"" = no value returned
;nil = failed
;"1.xxxx" = return value as a string
ACAD
12.6.2016    4272×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13622:Bulk import pages from a multi-page PDF into AutoCAD.
Tip 13607:Adding the block editor to AutoCAD Web app.
Tip 13552:Differential dimension X,Y
Tip 13468:How to change the drawing background color in AutoCAD Web? (black drawing)
Tip 13038:How to explode 3D faces (3DFACE) into outline polyline?
