CAD tip # 11665:
Tip 13091: | 3DSolSz - list of dimensions of selected 3D solids. |
Tip 12926: | How to import point coordinates from Excel to AutoCAD? |
Tip 12837: | RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables |
Tip 12830: | Converting pseudo-tables consisting of lines and texts to TABLE objects in AutoCAD DWGs. |
Tip 12479: | PkLength - export line lenghts to Excel. |
How to fillet 3D solid objects in AutoCAD?
The plugin Properties+ does not show up in Navisworks Freedom. « | » Which AutoCAD commands do exist also in the commandline (non-dialog) dashed version?
Featuring: Increase your productivity with our set of BIM add-on functions for Autodesk Revit CADstudio Revit Tools ![]() |
