CAD tip # 10799:
applies to: Civil 3D · |
Tip 13855: | DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder. |
Tip 13784: | Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT? |
Tip 12926: | How to import point coordinates from Excel to AutoCAD? |
Tip 12837: | RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables |
Tip 11581: | How to compare changes between two versions of a Revit BIM project? |
How to open gmax models in 3ds max?
Simplifying 3D drawings by replacing repeating 3D solids with blocks. « | » Cascading precedence of rental licenses.
Featuring: Save your floating licenses (NLS) consumed by inactive users - free unused licenses with LogOff 2006 |
