  Visitors: 5735
CAD tip CAD tip # 7125:
Faster loading of assemblies and projects in networks.
A - answer When loading larger assebmlies, models and projects over a network, Inventor or AutoCAD or other CAD application may react slowly. This is caused by accessing a high number of network files (xrefs, assembly parts...). Due to the default setting of Windows network parameters, these files may load slowly.
You can make this operations faster (increase performance) by increasing buffers for TCP/IP network operations (on the client computer; for older NT servers also on the server). Using the REGEDIT tool set (add) in the Registry in:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\LanmanServer\Parameters
the value:
SizReqBuf DWORD:14596 (decimal)
You can also further increase the SizReqBuf value - e.g. twice. This will increasy the memory for the buffer of network work items (WorkItem). The memory requirements will go higher but you will substantially increase the performance of file transfers.
Restart your computer and check the higher performance of network operations.
InventorACADADT
100% *  CAD,HP
22.12.2009    7766×
applies to: Inventor · AutoCAD · AutoCAD Architecture ·
Tip 6914:Running process WSCommCntr1.exe
Tip 6344:HYPERLINK is very slow (hangs) on the first run.
Tip 6187:Windows shutdown is very slow.
Tip 2398:How to change the Today bulletin board location for network installs?
Tip 2043:How to change a standalone (local) AutoCAD license to a floating license without reinstalling?
