CAD tip # 5845:
applies to: Inventor · |
Tip 13965: | Total length of sweeps in Inventor - wires, pipes, trusses, tubes, hoses (iLogic) |
Tip 13263: | Error when renaming assembly files in Design Assistant 2022. |
Tip 13227: | Reference Explorer - quick analysis of your project or assembly (file size, xref errors). |
Tip 13211: | Automatic numbering/renaming of multi-volume bodies in a part. |
Tip 13197: | How to transfer a model or sketch parameter to iProperties? |
An undocumented AutoCAD command sets CPU affinity. « | » How to transfer an entity between the model- and paperspace?
