  Visitors: 10238
CAD tip CAD tip # 6795:
FieldLink to display links between fields and objects.
A - answer The free AutoCAD utility CADstudio FieldLink displays temporary lines (arrows) between dynamic text fields and the objects, which properties are used in the fields.
So you can easily represent (visualize) links and relations (connections, dependecies) between text fields (texts, attributes, table cells) and their dependent drawing objects (entities) - e.g. between a boundary polyline and its acreage label. The lines also identify all fields depending on objects. The temporary lines are automatically erased on redraw or zoom operations. Alternatively, you can make them a permanent drawing geometry.
You can download the the FieldLink application from Download. Load it with APPLOAD and start the FIELDLINK command.
FieldLink
Sample drawing FieldLink (see CAD Blocks)
ACADADTMapCivilACADMABS
14.7.2009    9335×
Tip 13788:Green square - mathematical charade and parametric constraints in AutoCAD.
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13522:LookupXLS - populating DWG texts from Excel spreadsheets.
Tip 13442:How to easily count the number of certain objects in a DWG drawing in AutoCAD LT?
Tip 13426:Use of alternative units for arithmetic in dimensions (without square brackets).
