  Visitors: 9919
CAD tip CAD tip # 7847:
FIND does not stay zoomed on the found text.
A - answer The command FIND does not stay zoomed on the located drawing text - when I dismiss the Find dialog, it goes back to the original view and the found text is lost.
This behaviour was observed in AutoCAD version 2009 and the unpatched version 2010. Other AutoCAD versions keep the text zoomed.
Please check if you have an updated version of AutoCAD 2010 - see the service packs on Download
ACAD2010ACAD2009
10.3.2011    5923×
Prices - CAD eShop:
applies to: AutoCAD 2010 · AutoCAD 2009 ·
Tip 13749:How to add the SEARCH/REPLACE command into AutoCAD Web?
Tip 13459:DWG drawing version history directly in AutoCAD.
Tip 13414:Performance analyzer in AutoCAD 2023.
Tip 13340:Where is a given font used in my drawing?
Tip 13266:Where can I find the MAKEPAT command in Fabrication CAMduct?
