  Visitors: 6767
CAD tip CAD tip # 13737:
Formatting leading zeros in AutoCAD fields (and automatic field update).
A - answer Using lookup tables and dynamic blocks, you can in some cases solve the formatting of automatic labels (fields) using leading zeros (and the "+" sign) - that is, formatting that preserves the number of decimal places before the decimal point/comma.
An example of such a block ("Lead0") can be found in the sample DWG drawing FmtBlk.dwg - see Block 22544 for download. This block displays the formatted value of the current rotation angle. Similarly, a distance parameter, number of elements, etc. can be used. To align the resulting text, it would be neccessary to move the text position, e.g. by using another lookup table.
The use of the dynamic Lead0 block is then illustrated in the video:
The video also uses the "trick" of automatic update of the text field value (so no manual regeneration of the drawing is required). The LISP reactor is used for this, which updates the fields after each block grip edit. However, it is not suitable for larger drawings (performance). To activate it, load the following LISP code (via .LSP file or by copying it to the command line or to ACADDOC.LSP):
;Auto-update block fields after grip edit
(vl-load-com)
(if (not autoUpFldReactor)(setq autoUpFldReactor (VLR-Command-Reactor nil '((:VLR-commandEnded . autoUpFldCB)))))
(princ "\nBlock grip reactor active")
(defun autoUpFldCB (reactor objectlist / sset blk)
 (if (= (car objectlist) "GRIP_STRETCH")
  (progn
   (if (setq sset (ssget "_I" '((0 . "INSERT")(2 . "`*U*"))))
    (setq blk (ssname sset 0))
   (if blk
    (vla-SendCommand (vla-get-activedocument (vlax-get-acad-object)) "_UPDATEFIELD ")
(princ)
ACADACLTADTACADMPlantMapCivil3D
17.5.2023    69015×
Tip 13712:Why do I have an inactive "thousands separator" item in AutoCAD text field formatting?
Tip 13426:Use of alternative units for arithmetic in dimensions (without square brackets).
Tip 13006:Calculated property descriptions (tobogan slide from floor to floor)
Tip 13000:Labels of dimensional parameter values in dynamic blocks (parameters->attributes)
Tip 12790:Centered dynamic label (e.g. area label).
