  Visitors: 8876
CAD tip CAD tip # 11505:
Get name of the original Revit BIM model from DWG files in AutoCAD.
A - answer DWG files exported from Revit as drawing sheets contain internal information about the original BIM model (RVT project).
If you want to retrieve and display this information in AutoCAD, you can use a simple freeware LISP utility BuildingID. Download the VLX file Download, load it into AutoCAD with APPLOAD and type the command BUILDINGID. This will show the name of the original source BIM project and possible other information stored in the current DWG drawing originating in Revit.
Revit
30.6.2017    3049×
Prices - CAD eShop:
applies to: Revit ·
Tip 13800:Visually compare 3D geometry in CAD and BIM files.
Tip 13404:How to import an IFC file in AutoCAD?
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
Tip 12977:Easily find CAD/BIM document references (including missing ones) - Reference Explorer
Tip 12609:Dynamo - how to convert a raster photo to 3D model in Revit?
