  Visitors: 5202
CAD tip CAD tip # 8636:
GIS performance analysis in Autodesk Infrastructure Map Server.
A - answer One of the new functions in the web tool Autodesk Map Server version 2013 is the performance analysis report. You can use it to identify bottlenecks in generation and publishing of the contents of the individual map layers from various data sources.
A sample of such analysis shows that the longest part of the particular query (328.75 ms from the total 830 ms) was spent on generating the layer "Plochy povrch 0" of the class ZM_PLOCHA_POLY_0 and that this map probably contains only minimum of labels:
Performance Report
The "Performance Report" can be invoked from the Site Administrator console under the URL address http://SERVER/mapserver2013/mapadmin/performanceReport.php.
TB2013Map2013
16.5.2012    6011×
Prices - CAD eShop:
Tip 11159:How to load an ECW v3 format image in AutoCAD?
Tip 9962:Revit: long delay after you click on the application menu ("R")
Tip 9698:Data formats supported in Autodesk InfraWorks 360.
Tip 9276:AutoCAD reports some xrefs as "Unresolved".
Tip 9013:Multiple "Geospatial Coordinate Systems" folders in Autodesk products.
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
