  Visitors: 6793
CAD tip CAD tip # 11386:
Hatches in AutoCAD 2015 (and higher) do not display linetypes.
A - answer In my drawings, I have used hatches showing linetypes (dashed, complex). AutoCAD 2015 now displays these hatches only as plain continuous lines.
The AutoCAD version 2015 (and higher) offers a new system variable HPLINETYPE which controls displaying linetypes in hatch objects. Linetypes in hatches are off by default to preserve performance. If you want to show linetypes in hatches, set the HPLINETYPE variable to 1.
ACAD2015LT2015ACADLT
12.4.2017    4644×
Prices - CAD eShop:
Tip 13158:ScaleBB - scale multiple objects to their ref.points or bounding boxes
Tip 12633:Sol2SolH - convert DWG objects of the type Solid to Hatches
Tip 12429:HatchOverlap - check for any overlapping hatches in a DWG
Tip 12287:AutoCAD hatch flood-fill does not honor all boundaries.
Tip 12105:Select the smallest DWG object - MinOf utility.
Simply link AutoCAD LT blocks to Excel table data.
Excellink LT 2006 More info
