  Visitors: 7960
CAD tip CAD tip # 6792:
How to attach dimensions to a 3D model in Inventor?
A - answer You can add any 2D or 3D dimensions to a 2D or 3D view in Inventor.
Create a 3D view (e.g. isometric, rendered) on your drawing sheet. Go to the Annotation panel/ribbon and start the Dimension command. You can pick any geometry or points to add linear, angular or radius dimensions to your part or assembly model.
3D dimensions in Inventor
Inventor
14.7.2009    28885×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13836:How to reset view numbering in Inventor?
Tip 13819:Position and docking of the Measure palette in Inventor 2024.
Tip 13411:How do I set tolerances for several dimensions at the same time?
Tip 13228:DWG or DXF file exported to/from Fusion 360 has incorrect size (scale, 10x larger/smaller).
Tip 12974:Edge symbol on Inventor drawings.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
