New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
Place your Ad on CADforum.cz
CAD tip CAD tip # 10222:
Question
To move your screen view using the keyboard shortcuts you can use simple menu macros assigned to given keys - e.g. to the combination of Ctrl+arrow on the numeric keypad.
This is e.g. a macro shifting the view left by 1/3 of the current view size:
'_-pan (trans (list (* -0.33 (getvar "viewsize")) 0) (- 1 (getvar "worlducs")) 1)
If you want to add the keyboard panning to your AutoCAD, load/add (see the command _CUILOAD) the menu file kbdpan.cuix from the section Download to your AutoCAD environment. Then you can use the combination Ctrl+arrows on your numpad (up, down, left, right) to pan the current view, always by a fixed amount - a third of the view size.
ACAD
3.3.2015    19901×
applies to: AutoCAD ·
Tip 10299:Hide AutoCAD drawing objects with Ctrl+Alt+H.
Tip 10167:Keyboard shortcuts in Autodesk Fusion 360.
Tip 8289:Autodesk Navisworks keyboard shortcuts.
Tip 7925:DWGsync - synchronized co-viewing of multiple DWGs.
Tip 7620:Keyboard shortcut for Select Previous.
Back    All CAD Tips
Categ:
