  Visitors: 8137
CAD tip CAD tip # 12881:
How to attach multiple raster images to my DWG in one go?
A - answer Neither the command IMAGE nor IMGATTACH allow to select multiple raster image files at the same time. Mostly it is even not desirable, as you will still need to specify the insertion point and scale for the individual images.
But of you insert (attach) e.g. georeferenced raster maps, you can benefit from mass insertion of the images and their subsequent mass positioning and rotation. All in one go, in a single AutoCAD command.
The freeware application GeoRefImg offers (since version 3.1) the command IMAGESATTACH, (the ribbon Add-ons > GeoRefImg > Attach Images) which can be used to multi-select attach many images in one go. Select the bitmap image files from the folders in the left panel one by one. They can be in different formats. After pressing OK, the selected images from the right panel will be attached one below the other, in the default scale.
If there is georeference information for the individual images (their World files), you can the use the GEOREFIMG command to select all inserted images and these will be repositioned to the right locations, in proper scale and rotation.
ACADMapCivilADT
25.2.2021    5213×
Tip 13421:The MAPIINSERT command does not offer a georeference (data from the world file)
Tip 13234:How to place a GeoTIFF image automatically into the correct position?
Tip 9564:What are the .TFWX world files?
Tip 9139:How to place GeoTIFF images automatically to right positions?
Tip 7087:How to reconstruct a world file from a raster image?
