  Visitors: 5281
CAD tip CAD tip # 10246:
How to invoke a nested script (.SCR) in AutoCAD?
A - answer Calling a script with the SCRIPT command will terminate execution of the original (parent) script file, so you cannot nest AutoCAD scripts by default.
But AutoCAD - since version 2016 - offers another command - SCRIPTCALL) - which works similar to SCRIPT, but allows script nesting. After the nested (called, invoked) script is completed, AutoCAD returns to the execution of the former (calling, master) script, immediately after the SCRIPTCALL command.
ACAD2016LT2016
20.3.2015    11728×
Prices - CAD eShop:
applies to: AutoCAD 2016 · AutoCAD LT 2016 ·
Tip 13040:iLogic - display information about complexity of an Inventor part.
Tip 12926:How to import point coordinates from Excel to AutoCAD?
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
Tip 12644:How to identify parts and assemblies imported from STEP/IGES?
Tip 12629:As sunflowers follow the Sun... Dynamo script for Revit
Simply link AutoCAD LT blocks to Excel table data.
Excellink LT 2006 More info
