  Visitors: 4578
CAD tip CAD tip # 8917:
How to change multiple face colors in Inventor?
A - answer If you want to change color of multiple faces on a part, when the faces have assigned individual color styles (appearances) overriding the part material, you can use two ways.
You can select the faces individually, using the Ctrl key and clicks, and then use Properties to assign them the requested appearance (or the default appearance "As part").
If there are lots of faces, this way would be complicated. In this case select the part/solid in the browser tree, choose Properties from the context menu and in the dialog check the option "Strip color overrides". All faces will revert to the default appearance (color, material).
Inv2013
16.11.2012    13578×
applies to: Inventor 2013 ·
Tip 12365:How to show color print (sketch) also on the sheetmetal flat pattern?
Tip 11054:Difference volume (3D solid) between two TIN surfaces (sets of coordinates)
Tip 9972:Create free 3D PDF output files from any CAD software.
Tip 9668:Color fills missing in Inventor renderings.
Tip 9063:Flip 3D faces (front/back) in AutoCAD.
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
