  Visitors: 7588
CAD tip CAD tip # 14172:
How to change the design thumbnail image in Autodesk Fusion?
A - answer The small preview image (thumbnail) used in the Data Panel and in Fusion Team projects is generated from the so-called Home view (by default the diagonal iso-view) .
If you want to change it in your CAD or CAM models, set your own Home View in them.
Set the desired 3D view of your model, click on the arrow below the ViewCube navigation cube and then select Set current view as Home > Fit to view from the context menu. Save the 3D design. The new thumbnail will now reflect your new view.
Fusion360
100% *  CAD,CAM
9.7.2024    583×
Prices - CAD eShop:
applies to: Fusion 360 360 ·
Tip 13595:How to transfer 3D model incl. toolpaths from Inventor CAM to Autodesk Fusion 360?
Tip 12935:How can I set a single-stroke text font in Fusion 360?
Tip 12184:Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD).
Tip 11450:How to run Fusion 360 in a web browser? (URL)
Tip 8735:What are the .SIM format files?
VRMLout More info
