  Visitors: 5552
CAD tip CAD tip # 12306:
How to check if a specific application or process is running?
A - answer If you need to check in your LISP application whether a specific Windows application or process (items you can see in the Task Manager) is running, you can use the following LISP function:
(defun isRunning? (procname / apps item lst meth1 meth2 WMI)
  (setq WMI (vlax-create-object "WbemScripting.SWbemLocator")
        meth1 (vlax-invoke WMI 'ConnectServer nil nil nil nil nil nil nil nil)
        meth2 (vlax-invoke meth1 'ExecQuery "Select * from Win32_Process"))
  (vlax-for item meth2
    (setq lst (append lst (list (vlax-get item 'CommandLine))))
  (vlax-release-object WMI)
  (vlax-release-object meth1)
  (vlax-release-object meth2)
  (setq lst (vl-remove nil lst))
  (vl-some '(lambda (s) (wcmatch (strcase s) (strcat "*" (strcase procname) "*"))) lst)
For the procname parameter, use any substring identifying the runstring of the specific application or process - e.g. the parameter "acad.exe" should always return T, as AutoCAD is running for sure:
(isRunning? "acad.exe")
Is the Windows indexing process running?
(isRunning? "SearchProtocolHost")
ACAD
100% Win  CAD
8.7.2019    9787×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 14077:How to quantify the carbon footprint on a project in Civil 3D?
Tip 13977:How to publish a PDF to the same folder as a DWG drawing in AutoCAD?
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13878:SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions
Tip 13858:Is there also a SETBYBLOCK command?
