  Visitors: 5326
CAD tip CAD tip # 9852:
How to convert 3D CAD solids to Revit parametric BIM families?
A - answer A standard import of 3D solids from DWG and other CAD formats does not allow exploding and editation in Revit projects.
Using the import in the in-place component mode can help to bring in such 3D models and edit them in Revit. By adding reference planes and parameters you can convert the imported 3D model to a standard Revit parametric 3D family (.RFA file).
See the video illustrating the conversion process from an AutoCAD 3D model (retaining wall) from a DWG block to a RFA family:
RevitDWG
2.6.2014    36526×
Prices - CAD eShop:
applies to: Revit · DWG ·
Tip 13692:What is the precision in Revit?
Tip 13541:Using Twinmotion from Revit to visualize other types of 3D scenes.
Tip 13404:How to import an IFC file in AutoCAD?
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Tip 12671:Import Excel table by snapping a photo of it.
