Some types of simple 3DSOLIDs can be converted to surfaces with the CONVTOSURFACE command and then converted to 3D Meshes or 3D Faces.
But if you need to convert any general 3D solid, this method may fail. An arbitrary conversion to 3DMesh was usually accomplished using the 3DSOUT command (and possibly 3DSIN) in the older AutoCAD versions but as this command is not available anymore in the current versions, this way cannot be used either.
In AutoCAD 2011, 2012 and higher you can use the free LISP utility "CADstudio Sol2Mesh" and its commands SOL2MESH and SOL2FACES. These commands convert any 3D solid to meshes or separate 3D faces. You can download the SOL2MESH utility from Download and load it with APPLOAD.
For AutoCAD 2019, 2020 and higher, this tool uses a different conversion procedure. You can control the conversion smoothness with SMOOTHMESHMAXLEV.
Featuring: Use Google Earth images in your AutoCAD projects with the Plex.Earth Tools
