  Visitors: 5775
CAD tip CAD tip # 7093:
How to convert a polygon or a region to 3Dfaces.
A - answer If you want cover a closed polyline or a region with a "blanket" of 3dfaces, you can use the 3D modeling functions available in AutoCAD since version 2010.
Any closed polyline or a region can be converted to a Mesh object (2D). Just use the MESHSMOOTH command. If your polyline border contains arc segments, you may want to refine the resulting mesh with the MESHREFINE command. This will increase the density of the small patches and more precisely fill in the arcs.
The mesh can be easily converted to 3d face entities (3DFACE) just by exploding - the EXPLODE command.
Mesh
You can also use similar method to convert 3Dsolids to 3Dfaces.
ACAD2012ACAD2010ADT2010
2.12.2009    40930×
Prices - CAD eShop:
Tip 13559:How to find the number of faces of a 3D mesh object in Fusion 360?
Tip 13472:How to convert the structure of a volumetric lattice to a real mesh body?
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Tip 13021:Rotating model when hovering above a 3D point cloud. How to disable?
Tip 13013:Converting a 3D mesh to a 3D solid in Fusion 360.
